MajorF
I have sold my boat and have numerous parts/accessories for sale as a job lot for £275. The engine parts in the following list would suit KAD 42 & 44 engines.
Motor cruiser – Parts/Accessories
Engine air filters x 2 (New) MANN C3483/1
Engine oil filters x 2 (New) MANN W950/13
Separ Fuel filter x 2 (New) Kit No.15211-OEM
Sterndrive relays x 3 (New)
Rear view mirror (New)
Engine oil funnel (New)
Sikaflex sealant (New)
Spare Impeller (New – carton worn)
Alternator belt (New) Keypart 977542
VP compressor belts x 2 (New)
VP power steering belt (New)
VP prop removal tool 23161623
1 x B5 Duoprop (needs refurbishment)
Silverline 1200W sander/polisher for gelcoat
Numerous polishing pads, foam/lambswool
Draper wet & dry vacuum cleaner
Pressure washer
Sealey Vacuum Oil extractor
SeaBis electrolysis corrosion preventer
Pump kit for putting Rydlyme through engines
Sterndrive exhaust flap & rivets (New)
Spare shore power cable/plugs with carrying case (New)
Shore power plug (New)
Endless Breeze 12V fan (Large, square)
Rollo cassette water hose
Digital Multimeter (New)
Oil filter removal tool x 2
Large plastic buckets with lids for used oil
Ring spanner set
Spare belts x 15 Various sizes (Used)
Mechanics trolley (stained) used when anti-fouling
Funnels set
Antifoul removal tool – Bahco665
Jabsco electric toilet O rings
Smartwater forensic coding system
Stern Mini spotlight
Dimplex heater frost control
Tube heaters x 2 (Engine room & saloon)
Heater timers x 2
Blade fuses & extractor
Separ fuel filter O rings
Heat exchanger O rings
Sonar O ring
O rings set
O rings x 6 packs
Water pump bearings
Carling rocker switches x 2
Replacement EDC helm switch x 2
Toilet joker valve
Shore power plug splitter
Led torch
Led flexible torch
Stainless steel screws x 2 sets
Brake cleaner spray (Partially used) – belt dust remover
Engine protectant spray (Partially used)
iPad stand
Decal applicator
Sonax blue polish
Fender pump
Deck - foot polishing pads
Vinyl protectant spray (Partially used)
Windowize scratch remover x 2 (Partially used)
GRP hairline crack fix
SS Water/Diesel filler/caps
Anti-freeze tester
Jubilee clips x 6
Sterndrive anode
Can Jizer engine degreaser (Partially used)
Contact cleaner (Partially used)
Fender clips x 6
Speed Guard marine paint protection
Fabsil Universal protection
Halina binoculars
Karrimor waterproof bag
Diesel fuel container 5ltr
Items sold as a job lot only and not sold separately. Collection from Wickham, near Newbury or mutually agreed location within reasonable distance from Wickham. Any questions, please ask.
Pressure washer
Ring spanner set
Funnels set
Heater timers x 2
Sonar O ring
O rings set
O rings x 6 packs
Water pump bearings
Toilet joker valve
Led torch
Led flexible torch
iPad stand
Decal applicator
Sonax blue polish
Fender pump
Anti-freeze tester
Jubilee clips x 6
Sterndrive anode
Fender clips x 6
Halina binoculars
