CLB
The only issue I can see would be that of the fuel bill. Long term cruising on a 50ft flybridge planing hulled boat is going to be expensive, but if you can deal with that, then go for it. I am a tad jealous :encouragement:
Are there any liveaboards do it on a motorboat such as a planning hull like our recently purchased Fairline Squadron 50 1997? We have a total of 4 cabins inc. the crew cabin which provides for a lot of storage. I feel from the small amount of time on it that 2 of us could live aboard this.
Also, does anyone do part liveaboard and so still have a place back home but spends say 50% of their time on board. I don't care whether this is technically live aboard or not but just interested to find out more.
Thanks in advance.
We have a 48’ full displacement mobo, we’ve spent months at a time on board, but never as a proper live aboard. However we have all the facilities on the boat that we have at home. I’m sure that we could live aboard quite easy if we wanted to, so I can see no reason why you cannot do the same, and with a fair amount of comfort.
15 years of med living / cruising until ill health forced us to give up. Some personal observations
We met people living full time on 28' cats, 60' sloops and a 38' princess All happy.
We owned a 1980's vintage Bertram. 47' loa, semi hull and two 450 HP Detroits. Which we spent time upgrading and renewing. Winters In the eastern med are too cold in Dec/ Jan/ Feb and we made a habit of coming back to uk to keep in touch. We always left the boat out of the water after a couple of bad experiences with marinas and storms. Also gave me the chance to check and maintain hull, props and transducers etc.
As regards the hull form. I would recommend a semi every time. Med cruising is not all flat seas and sunny days. It rains cats and dogs, sea state can go from flat calm to ten foot waves in an hour and the wind can do a 180 in half an hour. A semi will cope when a planer has to come off the hump and torture its crew with corkscrewing. The trick is to use the revs to get the bow up to fend off the wave wash and smooth the ride as the hump pushes over the waves. At displacement speed @8 kts you have economical fuel use age. At planing you have around 20 kts to get out of trouble.
Most of your life is spent either on the hook or tied to a wall so living space is absolutely vital to maintain sanity and is more important than the number of cabins ( mostly unused and end up as dumping space).
Not all semis are "trawler yachts" (too boxy and ugly for me) so do your homework before you go shopping
We found the flybridge to be either too uncomfortable to use in bad weather, hot weather and night time, and the extra height acts like a sail when you're trying to dock in a high wind. I actually took mine off!
Finally get the best anchoring set up you can afford. Windlass, chain and anchor and a spare. It helps you sleep.
Good luck
That sounds like an interesting trip, any blogs of others who have done this that I can read?
Are you talking about our booked break to Prague or the post by Bertramdriver?
as said before we have all the comforts of home and more on our boat and if all goes to plan our last trip will be
via -Holland, Luxembourg, Germany, Austria, Hungary, Slovenia, Croatia, Serbia, Bulgaria Romania to Istanbul.
this is as others have done
What sort of a boat do you have. I do know of some forumites who live aboard a similar boat to ours but many try and push us towards a displacement or semi-displacement which I'm nt interested in or at least not at the moment.
By the way. You can get an insight into life on a mobo by reading my book. The Bertram, the Aegean and Two Virgins. Available from Amazon and all good bookstores
Sorry about that. It's out of stock at the moment. They would have stock if nobody was buying it so it seems it's my fault for not forcing them to carry higher stocks. All I can suggest is that you place an order and play patience for a few weeks.I just had a look for your book and it’s not available on Amazon right now.
