BobE
Just took the good old Garmin 12 XL outside and had a little play
Made waypoints on the same meridian (W 001deg 46.023 ) at
N 00 deg 54.930
N10 deg 54.933
N20 deg 54.934
N30 deg 54.932
N40 deg 54.930
And told it to go to..
Got all at 180 degrees ( of course) and ranges as follows
2992 nm, 2395 nm, 1798 nm, 1199 nm, and 600 nm so there's a slight descrepancy in the ranges which could partly be the in the third place of decimals of the minutes but ????
Then I did the same but made waypoints all at the same Latitude 50 deg 54.934 but different Longitudes i e
W 046 deg 46.032 1682 m @ 288 deg
W 096 deg 46.032 3337 nm @ 310 deg
W 136 deg 46.031 4291 @ 332 deg
and
E 179 deg 46.031 4707 @359 deg
Then made a waypoint @ 11 deg 46.023 west i e 10 west from me
and got 379 nm @ 274 deg...
So the GPS must use great circles when we ask it to "GoTo"
The chart plotter allows one to draw a line from one place to another and gives range and bearings from & to...
Across Biscay it gave about 360 nm @214.2 deg
Maybe we should be using the GPS for all the calcs?
Next test maybe be to put the GPS in simulation mode and try across Biscay???
Cheers Bob E
N 00 deg 54.930
N10 deg 54.933
N20 deg 54.934
N30 deg 54.932
N40 deg 54.930
and
Cheers Bob E
