Pye_End
Agree. RH. Nothing wrong with that style of prop. Yes to clockwise from astern, and yes I agree with you gearbox ratio comments.
Regarding installation by 'others' for this sort of thing, from my one experience it is worth double checking everything. Your comments about 'astern and reverse' are very familiar and happened to me! I would also check the gearbox oil, and how well the alignment has been done - does the shaft run free by hand, and is it centred in the stern tube! Do it personally rather than trust anyone else.
Please somebody correct me if I am wrong, but are there two different setting for the gear lever on a Morse controller? - ie check the lever is travelling the correct distance. Not sure if the wrong one would affect the rpm in the way you describe, but I would check it anyway. I presume the 'throttle' is actually being fully opened when you think it is at max rpm?
