doug748
Here is mine from last year.
Gert 30mm multiplait with and eye one end, for the cleat and a ss thimble on the other. The thin line is secured to a second cleat and also locks the eye onto the first with a turn or two, as does the float line:
I find a swivel essential. The one shown is of a size beam trawlers use to secure their tackle so should endure till the pins wear. I fix the pins with cable tie + monel wire + spilt pin through the protruding end of the thread - of the three the only one which has never failed is the split pin
Quite short so brings the boat close to the buoy and does not foul the mooring when away sailing; stiff so helps hold the buoy off in light weather. One point fixing means it is easy to remove, which I did/do a few times a season.
The op could bring this thing aboard and secure the eye with lighter stuff to the two cleats but you have to be sure that your bow roller is strong enough.
The eagle eyed will see the plastic pipe needs replacing. I would probably use fire hose.
