Jaguar 25
Advice please.
We are about to set up a mooring in Langtone Harbour having been allocated a position by Tudor Sailing club. As a minimum the mooring includes a sinker but nothing else. So, we need a mooring buoy, 3/4 inch chain plus 3/4 inch shackles to make the connection between the sinker and the mooring buoy lower swivel. So here are my queries:
1. What is the best way to make the connection between the sinker and the mooring buoy lower swivel, can you walk out to the mooring at low water and fit everything or is it better to use a dinghy and time it for when there is about a couple of feet of water at the mooring and reach down to the sinker to make the connection?
2. We have normally been limited to connecting to club/marina mooring buoys at the top of the buoy. However, some advice indicates that we should connect the mooring strop and chain to the lower mooring buoy swivel by means of a shackle then a separate swivel and this shackled to the chain and strop.
3. Is a 450mm dia mooring buoy OK for supporting 12 foot of 3/4 inch chain?
I know there are many ways of doing the above but what is the perceived wisdom of the forum?
