Mooring Advice
Mr Grumps might well have problems mooring his boat stern-to in the marina, so how do you experts go about it?.
I never managed to back up in a narrow slot with a single engined sterndrive if there was a crosswind without entertaining the gang and dinging the boat.
How is it done?
Geoff
DepSol
6 Oct 2001
Guernsey
Practice, I slow my boat down to 2 knots before I reach my berth and put the engine in neutral. I then swing over the steering and aim right as my berth is on the left until I get close to the boat in front of me. At this point I am going very slow.
I then straighen the steering wheel to a central point engage reverse gently and steer her in. Easy.
Dom
2003 is going to be a good year for me
Renegade_Master
27 Jan 2003
Spain
easier than mooring buoys eh Dom/forums/images/icons/wink.gif
<A target="_blank" HREF=http://www.suncoastmarine.co.uk>Sun Coast Sea School & Charter</A>
tr7v8
30 Nov 2001
Kent
When I was moored at Wargrave with the Dolphin we were at the end of a very long channel on a linear mooring. Each side of the channel was moored some very expensive boats. You either reversed in and went out forward or the other way around, I got quite accomplished in the end this was a 20ft 2 + 2 cruiser with a 25HP Evenrude. Soon got the engine tuned so it stayed running!
Jim
Dom it didn't work for me. If I went in slowly my bow went off down wind and hit the front (with a vicious anchor) of the boat next door. When I tried to steer in, the boat rotated about its centre and the bow went for that anchor again.
I tried going in fast, slewing the bow upwind, just scared myself - and the guy next door. I practiced in the winter in the works car park (with the car) - scared a lot of people didn't help.
Have to admit I gave up and bought a twin, much easier
Geoff
<P ID="edit"><FONT SIZE=-1>Edited by GES on 18/02/2003 13:33 (server time).</FONT></P>
DavidJ
15 Jun 2001
The experts I guess are fishermen. Have you seen their boats covered in huge fenders. They just drive into a gap and let the fenders do the rest.
I think sometimes we have a car fixation about a boat, that we try very hard not to touch the boat next door with our fenders. My advice with a single prop and a cross wind is to get yourself in a safe stationery position and use ropes.
David
Try this docking simulator:
http://home.attbi.com/~mltsoftware/docksim.html
I've not managed to do it yet with a cross wind
Practice - but do it somewhere safe...
Find a transit (for example, two fixed points on either side of a river), and practice 'ferry gliding' in a variety of wind and tide conditions. Practice keeping the boat on a straight course between these points. As the bow will inevitably weathercock in a blow, the most controlled approach at slow speed is often going astern with the bow slanted downwind.
Assuming you have a single engine, learn to understand and predict the effect of paddle wheel effect under all permutations of forward and astern drive, and rudder/steering angle. This will help you to make the final swing into your finger berth.
The slower you can do it, the better!
Hope this helps.
Retires gracefully...
Nigel
<hr width=100% size=1>Medway Motor Yacht Club
<A target="_blank" HREF=http://www.mmyc.co.uk>http://www.mmyc.co.uk</A>
dangcharios
24 Jan 2002
Ibiza. Baleares
The trick is to keep the power on if you slow to much you lose the steering
take an R Y A Powerboat course the instuctor will show you how to turn a single engine boat at 360 dgs
Trevor_swfyc
19 Jan 2002
Crouch
Mooring or Berthing
Sorry to be pragmatic but as far as I know you do not moor in a marina. I have become aware however that the Crouch Harbour Authority are looking into it, evidently they are investigating if a marina berth can be designated a mooring. Not sure what this is going to lead to, but watch this space.
While on holiday in the Ionian I saw a flotilla lead boat reverse in a strong cross wind he dropped the bow anchor about 20yds off and came back into a gap flat out /forums/images/icons/shocked.gif ok I guess if nothing goes wrong. The yacht did have wheel steering which does help but I wouldn't attempt this technique myself.
Trevor
Trevor_swfyc
19 Jan 2002
Crouch
Re: Mooring or Berthing
My yacht has tiller steering and a large transom hung rudder if the tiller gets out of line at anything above 1 knot it whips out of your hand and slams hard over.
Hope this answers your query?
Trevor
Thanks for the help guys, I really tried everything.
I had instruction from two professional instructors. One of them dinged the boat good and hard ! To be fair it was very windy.
The problem was that I had to back into a slot about 3 ft wider than the boat. Quarter way in and the downwind drift started, steer the stern upwind a bit to avoid crashing into the other boat, my boat rotates - bow goes twice as fast down wind and wraps round that ****** anchor sticking out of the bow of the other boat.
I changed my marina in the end to one where the berths are aligned parallel to the prevailing wind and then as I said bought a twin.
Geoff
Happy1
N/A
18 Feb 2003
Europe
Ges, I got a 10mtr berth for a 6mtr boat to give me more room to park.
<hr width=100% size=1><font color=purple> "You only see what you recognise, and you only recognise what you know" <font color=purple>
Good Idea Mr Happy but on the South Coast they give you a 6m berth for a 10m boat so you have to go in stern first else you cannot get off.
As you don't have this problem, you can go in forwards - MUCH easier
If you find the wind a problem, a small vane/flag on the bow rail is very useful
Best of luck with the boat - great fun but beware of adding too much weight, it really kills the performance
Geoff
