jwilson
Just looked at the specs and it is a foam sandwich hull, so there's no chance that the foam has soaked-up the moisture.
What with this and the surveyor clearly using the wring setting on his moisture meter, you might want to find another surveyor who actually knows what he's looking at.
Even if the foam in a foam sandwich hull is nominally closed-cell, it can still absorb some water if either skin is breached through damage, or not fully sealed fittings.
Re Tramex ranges: if Range 1 gave 40, the correct Range 2 would have been off the scale. Range 2 is much more sensitive than 1 to take into account that whilst wood contains a fair bit of water, GRP shouldn't. Was the range statement a typo ??
