BabaYaga
I have this question regarding the installation of a tiller pilot, which requires some background. So I will start with the essential:
Has anyone experimented with reducing the recommended distance between the rudder rotation axis and the actuation point on the tiller in order to achieve a greater degree of tiller helm (and quicker tiller movement)?
The background:
I have had an Autohelm ST4000 since 1994. This year I replaced it with a new Raymarine EV100 tiller pilot pack, which uses a tiller drive that is identical to the old one, as far as I can see.
The installation instructions for the tiller drive, regarding measurements etc, is also similar to the ST4000.
On occasions, I have experienced that the pilot, when trying to maintain the right course, struggles to do so because it hits the end stop. That is to say the rod is fully extended or retracted but this is not enough to get the boat on track. (Usually this happens when the sail balance is far from perfect and I am at the mast, trying to reef the main).
I have noticed that when the same tiller drive was used for the SPX-5 pilot (about 10 years ago or so), Raymarine in the installation instruction gave the option of reducing distance between rudder axis and actuation point from normal 457mm (18") down to 356mm (14").
I understand that doing so would not only increase the degree of helm, but also decrease the maximum force on the rudder, which I think could be acceptable.
But I would be grateful for any comments, especially from those who have tried this alteration.
The background:
