Thank you. I think we’re going to take one of the windows out again and measure just to make sure.I think that @Firefly625 has a Mitchell 31 - he might be able to help with the info you require?
Indeed I do have a Mitchell, but I would not really like to guess the thickness of the gel coat. I have never measured it. Also as such bespoke boats many being built by different yards I’m not sure many two would be identical. There was a chap called Roy asking similar on the Mitchell Facebook group, if this was you then my recommendation still stands... drill a hole and have a look. Good luckThank you. I think we’re going to take one of the windows out again and measure just to make sure.
We went down to the boat today and took one of the windows out. Measured 4mm. Ours is a Mark 1 version but as you say all builders will be different.Indeed I do have a Mitchell, but I would not really like to guess the thickness of the gel coat. I have never measured it. Also as such bespoke boats many being built by different yards I’m not sure many two would be identical. There was a chap called Roy asking similar on the Mitchell Facebook group, if this was you then my recommendation still stands... drill a hole and have a look. Good luck
(if you are not Roy, and not on the Facebook Mitchell group, I would recommend you join!)
