Mirror dinghy repair.
  • Thread starter Thread starter Guest
  • Start date Start date
The kids Mirror has blown off it's lump of wood under the bow which has punched a hole in the forward sealed compartment. What would be the best way to repair this? Ta.
Not an easy one this and depends on the quality of repair required. You can buy whole panels from trident, strip out the old and fibreglass in a new one. If like me you aren't that bothered cut out the damaged part and form a lip around the hole with ply or timber that will take a reasonable screw (6 or 8 mm). Glue and clamp this lip in place and use countersunk screws if you feel necessary. Once this is dry you can bed the repair patch onto it using glue and screws again knowing you have something solid to attach to. Fill and Sand to finish.
Good Luck
Yoda
