Northern Star
I have the Mikuni MY30 and when it smoked a lot I just changed the glow plug and it was fine. They do also need plenty of volts and will shut down if they drop too much.
Mine has also been thermal cutting out recently and there is a temp sensor inside the air outlet that may need re-setting, you remove the outlet hose and press the button in the centre of the thermal trip.
Mine is very old so it needs a good service and the seals probably done but I did pick up a second hand unit off e-bay for just £95 so may fit that and see if it is OK.
As others have said there are far cheaper options available now from China and elsewhere.
