mattnj
UPDATE - Slight change of plan...maybe?!
I have been busy trying to finish it off over the weekend but found myself at a fork in the road....
The original Honda GX25 micro genny is 95% complete, as per my original spec, near enough, the engine speed is held by a servo control, the alternator regulator is managed also by the PIC microcontroller and is fully adjustable and programmable, anything you like really, the water cooling system is done, it bolts onto the engine, so no drilling needed, and makes a huge difference to the running temps when put in a box with zero ventilation.....so there i was just getting ready to tidy it all up and make it all a bit more permanent...but i have just aquired a Yanmar L35, 3hp electric start diesel, for a cheap price....so i think i will wait till it arrives then seriously consider migrate the electronics and alternator onto the diesel and finish it off from there, making another water cooled manifold system or maybe i should finish this 100% first, tricky one...diesel off the main tank is so much more appealing although it will be a fair bit bigger and heavier, i will of course be able to get a load more amps too at 3hp.
As for the performance, it is about what i expected, it will happily do 25-30amps, but that is getting towards the upper noise levels on the engine, it is quiter at 20amps downwards, the pics show it running at fast idle where it produces just 3.4amps
vids of it running to follow on youtube
