Polybus
G'day,
I've just finished rebuilding my 2000 Model Mercury 3.3 2 Stroke (a rebaged Tohatsu 3.5hp I believe) - I bought it as a seized wreck.
Everything works OK - except the Tell Tail. It runs - Gears (Forward & Neutral) work - all seems good, except the Tell Tail. As part of the rebuild I put in a new Impeller/Water Pump kit.
Trouble Shooting so far.
1: Pulled The Gear Box off - dipped it in water, and turned the Drive Shaft (Clockwise) with a cordless drill - a good flow water came out of the top of the Pump Housing.
2: Pulled the whole Power Head off, and placed the entire leg into the Test Tank - turned the Drive Shaft with a drill - water came out of the top of the water pump tube, and started filling the water galleries.
3: Pumped water up into the Tell Tail pipe (Power Head still off), and watched it come back out of the hole at the bottom of the block's water galleries.
4: Reassembled motor again - run it in test tank - nothing - no water comes out of tell tail.
5: I have probed/cleaned the holes in the water galleries leading to the chamber around the cylinder.
6: With the motor sitting upright (as mounted on a transom) if I inject water into the Tell Tale pipe - a second later it will flow out of the Exhaust hole on the bottom of the leg.
7: With the Power Head off, and upside down - I can pour water into one (of the three) holes leading to the water jacket around the cylinder - once the chamber is full with water, I can see it overflowing through all three holes.
8: I have gently drilled out the actually Tell Tale nipple - it is clear.
Any suggestions as to why?
I was wondering if I have to prime the water pump, but when I test it with a drill, it self primes without a worry.
Other observations...
1: Smoke/Exhaust comes out of Tell Tail Pipe at times
2: I have tried the Impeller with the vanes oriented both directions
3: Test Tank water is well above the Cavitation Plate - at least 10 inches above it.
4: I have visually confirmed the Water Tube is fitted into the top of the water pump.
So in summary:
- From the drill test, I can see that the impeller is working - the water pipe is clear - and water is getting up to at least the water galleries at the base of the Power Head.
- From injecting water into the the Tell Tale - and from visual inspection - and from probing/prodding the holes - I can see that the water galleries around the cylinder seem to be clear
- From filling the water jacket around the cylinder - and seeing water coming from all three holes - I believe they are all clear.
- The Pump/Pipe/Leg sections work find (as per the drill test) - there must be something screwy going on with the power head water galleries that I'm not understanding....
I cannot understand why the water is not flowing through the whole system.
Can anyone help?
I'm wondering if the turbulence in the test tank from the exhaust is preventing it sucking water into the water pump - I have tried it both in Neutral and in Forward, and also tested it with the prop removed, but the turbulence seems to be coming from the exhaust bubbles rather than the prop.
My next step is to take it down to the River/Lake and test it down there....
Unless someone has any other ideas in the meantime ...... I'm stumped.
So in summary:
Can anyone help?
