kingsebi
I changed the thermostat on my OM 636 (found one that fitted the three hoses in the previous owners spare box) and now the motor overheats.... One time it ran a good ten minutes because I had to get out of a small anchorage. When I turned it off the needle of the temperature gauge was at maximum.
Now I'm scared the head gasket went. How do I know? There is no water in the oil. The motor starts and runs normally, but when the temperature goes up it doesn't stop at 80 degrees celsius but goes past 90 and then I shut it off to prevent further damage. That happens in the course of ten minutes.
How can I rule out that it's the head gasket?
I can't source a thermostat. Is there a way to do without?
I put the thermostat in boiling water to test it but saw no change. Does this mean its not working?
The arrow on the thermostat has to point away from the heat exchanger, right?
Edit: The raw water side of the cooling system seems fine, there is plenty of water flow.
Edit2: After I shut it down I open the heat exchanger pressure cap and cooling liquid pours out.
