bluedragon
I've just fitted a new mechanical voltage regulator (YES...they are still made!!) to my Dynastart. Although the Dynastart was completely reconditioned a few months ago by LSUK, they couldn't do much to overhaul the old Bosch regulator. They did however find a alternative Dynastart regulator in a catalogue and ordered this for me. The difference is amazing (in fact too amazing)...the Dynastart now wants to pump nearly 16V at 15A even into nearly fully charged batteries! Something is not right here...in fact I'm wondering if the 14V / 17A spec on the regulator means it's for 14V systems (are there such things??). Anyway, today, in the best tradition of messing with things I took the cover off and played with the adjustment screw on the regulator coil. Quarter of a turn clockwise has dropped the voltage and current to much more sensible levels. So, my question is - how does one choose the correct set voltage and under what conditions. My inclination would be to set the voltage to give a few amps to a fully charged battery at normal cruising engine speed, and ensure that this voltage is somewhere around 14.5V (certainly not above 15V). Does anyone have a more precise method I could use?
My batteries are a) Car battery - 65AH standard type for diesel cars from Halfords used for cranking and glowplug only b) deep cycle / start combination battery sold for boats as the service battery (75AH). These are linked via a voltage sensitive relay set at 13.6V at present. Both batteries are less than one year old and appear still in good condition.
