pugwash60
Sailing yesterday (Wauqiez Gladiateur) I noticed the rigging was a little slack particularly the baby stay. - Downwind in windy and gusty conditions the mast was pumping a bit and felt ‘wobbly’. I’ve not seen this before. I tightened up the back stay a little, halfway to my normal upwind and windy setting but things were still not good. I have a hydraulic tensioner and batten with markings on it to guide me. I was about to tighten up the baby stay when I suddenly wondered about a stalock fitting I’d fitted over the winter on the back stay. Looking at it, it’s possible that some wire may have pulled out of it - slightly fearful for the mast I quickly handed the sails and set the halliard as a back up stay. It’s possible that I stuffed up fitting it and got a wire caught in the slot in the cone. Before i disassemble it I guess I need a new cone to refit?
If it’s not the backstay I can’t think of any reason that the rigging should have slacked off so much. I had been sailing a couple of days prior to this in quite windy conditions, is it possible I can have stretched the wires enough to cause a loose baby stay? Is there anything else I should check?
Rigging was all set up at the beginning of the season with a tension meter. I did a regatta early in the season then nothing for a couple of months (off at work). All bottle screws have been wire locked so they have not slackened Off.
Thanks.
Thanks.
