crown22
Just about to make an offer on a secondhand one.My boat is an Atlanta Viking 8.5 with a mast length of approximately 30ft.Any advice appreciated.Thanks
My 35 ft mast is in a tabernacle on my 9m cat. Not a problem in the last 45 plus years and my boat is one of 250 odd. There should be support to the keel / bulkhead to prevent the deck from sagging. The reality is that I have only used the tabernacle once to lower the mast and the other times a crane.Just about to make an offer on a secondhand one.My boat is an Atlanta Viking 8.5 with a mast length of approximately 30ft.Any advice appreciated.Thanks
Ensure the base of the mast is supported by the deck and is not hanging only on the pivot pin. Failing to do so caused my mast ro adopt an hourglass shape by the pivot pin. The solution for my mast was to remove VOL-au-vent section and rivet in a replacement section, then drive a wedge between mast base and deck to support the mast from below.
I had a tabernacle on my Parker 275.
I used it every spring and autumn to lower an raise the mast.
As other has said it is very difficult to keep the mast on the centre line, unless you have a seriously good means of support. Either some strong well we'll trained people, or a means of keeping the shrouds tight, as the mast is lowered.
I used a block placed high up on the gable end of the clubs boat store. The sheave was about the same height as the hounds, and the sheave for the jib halyard, and used the jib halyard to lower the mast. This arrangement kept the lifting/lowering point above the mast, making it inherently stable.
I realise that this isn't always possible, but it worth looking for a strong point high up to give a better angle for the rope taking the load.
It the whole process so much easier.
Thanks for the video - we've a tabernacle on our boat's mast point and I've often wondered how its supposed to work with raising/loweringI can actually raise / lower that mast on my own with that frame ...
can I ask - are you supposed to loosen the standing rigging at the sides before hand (tbh I'm not planning on doing this, more just curious) ?
cheers Refueler - I'd often wondered how people do the lowering and what happens with the standing rigging
We're possibly looking for a bigger boat (as we'd hope to venture across the channel and be able to do some canals in the future) so that's good to understand a bit more how tabernacles can work. We've seen a few boat listings with a 'mast lowering system' with a pole but weren't sure how the boats do it. One of the boats had mentioned he had A frames he could include so we'll try and figure out that some more![]()
