Mast Pop rivets
Douglas
14 Oct 2004
London
Any particular reason against using alloy popers from B&Q (£!.50 per 100) instead of Monel (£2 for 4!) on low stress mast applications eg VHF mount?
kingfisher
7 Nov 2001
Belgium, Holland
Monel rivets: inner pin of stainless steel is isolated from the aluminium mantle: no galvanic corrosion
B&Q: no isolation
OK to use BQ when:
Fixation is away from salt water (i.e. top of mast, and even then)
Dose of sikaflex is applied when placing rivet
Obi-Wan
http://sirocco31.tripod.com
Boathook
5 Oct 2001
Surrey & boat in Dorset.
For the few pounds involved I would use the correct rivets. Climbing up the mast is a pain and if the rivets fail it's bound to be when you really want to use the radio!
