FairweatherDave
Due to the contour of the deck around the mast I can't do a cableport but can do a swan neck fitting. The next issue is making a nice job of the connections below deck. Currently they have been "chocolate boxed" and taped and then sit on top of a headlining panel either in the heads or just outside the door. I am thinking a junction box might be nice, but before that should I be doing better than chocolate box connectors? The VHF would be its own kind of join but the radar has 12 joins via chocolate box type, the wind instrument cable I'm not sure what to do and I need to replace the tricolour and mast head connections which are expired deck plugs at present. Suggestions of good connectors welcome. Obviously I need to be able to disconnect and remove the wires through the swan neck fitting. Part of the reason for posting is to see how people hide the wiring joins, do people fix stuff to the underside of the deck in a tidy way or do most let it just sit on top of the headlining panel (if they have one).
