Maritime Instrument Identification
Capt_Scarlet
9 Nov 2001
Oxfordshire, England
A friend of mine has an as yet unidentified maritime instrument:
Housed in a wooden case about 1 foot square, it consists of a gimballed moveable dial with an accurate engraved compass scale. On one side of the case it has marked "ships heading", and instead of a compass needle, it has a rotating sighting arrangement which levers up to give a small aperture on one side, a long slotted piece on the other side with a wire in the slot, and a small mirror hinged at the base of this slotted piece.
What exactly was it for, how was it used, and does it have any value?
I don't think the Austute had one.
Thank you.
sarabande
6 May 2005
perhaps it's the bit that fits on top of a standard compass to give a bearing ?
If so, it's bearing plate with an azimuth mirror.
Piccy will tell :)
prr
31 Mar 2009
Guess...used as an aid to calculate compass error (deviation) when having the compass swung?
iantitanic
11 Sep 2006
Milford Haven
Pelorus
Hi there it sounds like a pelorus usually used to take bearings relative to ships head to calculate compass error, position or risk of collision there should be brackets to house it usually in positions which a bearing from compass is not posible, its a bit of an old fashion gyro repeater. it is a usefull piece of equipe but you need one person to read compass heading simultaneous to peloros bearing bein taken.
Bilgediver
6 Jun 2001
Scotland
