Mariner Outboard
markju
28 Apr 2007
Southampton, hampshire
Hi. I have just picked up a small GRP dinghy and outboard for not very many of my pounds and am quite pleased with the dinghy. Going to use it to take my nephew fishing in the local rivers etc.
The problem is with the outboard, which was kind of chucked into the deal almost as an afterthought.
Its a Mariner 2 (2hp?) serial number 646-018322. I believe this was the same as the yamaha of that era?
its not seized but is going to need a bit of fettling i think.
Does anyone know of a website where i can gather a bit more info particulary a diagram of the internals etc.
Dont mind putting a little time in this as i got it quite cheaply but at the same time dont want to flog a dead horse.
sailorman
21 May 2003
Here or thertemp ashore
Vic will be along soon ;)
mariner, yam et al were all Tohatsu engines re-badged
Lakesailor
15 Feb 2005
Near Here
It'll be fine. I have a very old Tohatsu (same thing) Mine doesn't have gears but the Tohatsu dealer can't tell me if it's 2 hp or 3.5 as it seems none of the early ones had gears. It doesn't even have a serial number.
You will find a directory here with various pics of the internals and also the items titled "section" plus a number, are exploded diagrams.
If it turns out not to be the same motor I'll be surprised, and you'll need to look elsewhere. :D
markju
28 Apr 2007
That looks just like the little blighter thank you.
KREW2
20 Jan 2005
Dorset
Mine ran well for 6 years with very little maintenance, so this year I put in a new impeller, and cleaned out the waterways.
Two months later I went to start it and it had seized. I stripped it down and and found it was the main bearing. After working it loose and reassembling it started first pull, and runs well, but it does sound a bit rough.
Maybe it will be better if I run it on a stronger mixture?
VicS
13 Jul 2002
646-18322 makes it a Japaneses model from ca 1978 or 79
I think you may be right in believing that they were re-badged Yamahas in those days.
Youll find exploded diagrams at http://www.boats.net/parts/search/Merc2/Mariner/2A/646-31100 AND BELOW/parts.html
You should be able to download an owners manual from http://download.brunswick-marine.co...isnew/desc?mod=4&lang=EN&categories=OUTBOARD$ Its not always easy to find the right one though
?? if the link works http://download.brunswick-marine.com/filereader/file/pdf/4/enen/outboard/1985/mariner/43897r85.pdf but its a big file
Lakesailor
15 Feb 2005
Near Here
If you are using 100:1 you are short-changing it. Use 50:1
I replaced the top main bearing (under the flywheel). If yours is still a bit rough maybe the bearing you didn't do needs changing.
VicS
13 Jul 2002
The manual says 50:1
the similar/ identical Yamaha was badged up as 100:1 :(
markju
28 Apr 2007
Well...short update. First of all thanks to everyone who replied.
Cleaned the points and plug and got a nice spark.
Cleaned a bit of gunk out of the carb and stuck some fresh fuel in.
Put a 17mm socket into my cordless, that takes care of winding the beast over, electric start now!
Started and ran quite well but zero water output. Checked the impellor - that was past its best so a new one in there, and cleaned all the waterways out in the block, (found that info on this forum after a search), every way was cock full of salt, and now it runs quite nicely. Think the gasket is playing up on the waterpump as a lot of water came out of the exhaust although some also came out of the water outlet holes below the engine so at least it seems to be circulating nicely.
After running for about ten minutes, the head was hot but not so hot that i could not keep my hand against it. Is that about normal?
I have to say i,ve quite enjoyed playing around with this over the last couple of evenings.
Lakesailor
15 Feb 2005
Near Here
If it's overheating you won't be able to put your hand on the head without going "ouch". Most of the water should be coming out of the exhaust. The little holes are just for reducing back pressure and steam will show there if you are overheating.
Most outboards will show up their problems better after a 15 minute run under load, on the boat.
That's your next step.
Seajet
23 Sep 2010
West Sussex / Hants
I have one of these; the water from the outlet should never get above cold / luke warm when putting a hand under it.
They do clog up with salt, requiring a good flush through with fresh water as frequently as possible, and the head off in the winter to check and clear the waterways.
Ben Dockrell 22
1 Apr 2012
Planet Earth
With the cost of powerful outboards easily going into the tens of thousands of pounds it becomes very worthwhile to learn about building these motors from scratch or getting components from those bought as damaged.
CreakyDecks
9 Sep 2011
Not rude at all, just curious. In the last half an hour you have suggested that 1.2mm wall thickness stainless tubing is a suitable material for making deck fixings and that old 2hp outboards might cost tens of thousands of pounds. Neither of these things are remotely true on planet Earth.
Steve Clayton
22 May 2003
Benitachell - Spain
www.aloeland.co.uk
It may be Planet Earth in a parallel universe where it's all topsy-turvy. That said I'm perfectly happy where I am.
