marine boat toilet
tinny tim
28 Dec 2023
The add states the following
Warning​
The cable entry point must NOT under any circumstances be submerged. The mounting thread and cable entry must be above the highest level of the liquid.
I just dont understand what it means! are they saying you can unscrew the mounting thread and draw in some of the cable?
https://za.rs-online.com/web/p/float-switches/7621036
But that one states the following
Two Independent Switching Points
Lower Float Make on Fall, and Upper Float Make on Rise
Meaning that the on off position is allready set. Or are you saying the tube extends? as I do see it stated in listing
https://za.rs-online.com/web/p/float-switches/8697615
But dose it telescope?
https://za.rs-online.com/web/p/float-switches/2051304
They dont acrually state that they are for wast tank usage. As our friend above stated that a lot of float switches are not suibable for waste
https://uk.rs-online.com/web/c/auto...float-switches/?applied-dimensions=4294688602
rs components???
tinny tim
28 Dec 2023
Just Google "lift station float switch." Very common, can't foul, easy to replace.
So is this the same as this one
If you wish you can have any number and positioned at various heights
https://za.rs-online.com/web/p/float-switches/3488021
You can set this type to various heights as many as you wish
They bough have some device in the middle. is that device for mounting to the tank and if so can the wire go up and down it bough ways?
Alex_Blackwood
19 May 2003
Fareham
Sorry, yes they can foul, in more ways than one! Seriously having worked with sewage systems on ships with all sorts of indicators and sensors. I can categorically state that if it is in the tank it will foul, at some point. That applies to all types of sensor, even the so called solid state capacitive types. You can only start to imagine what a bit of wet bog roll can get up to when let loose! Not to mention the stuff that can "Grow" on them😵‍💫
tinny tim
28 Dec 2023
But do you use the blue chemical?
tinny tim
28 Dec 2023
vyv_cox
16 May 2001
France, sailing Aegean Sea.
coxeng.co.uk
I see a lot of DIY on this toilet; but I dont see any waste tanks to it
Suggest you look a bit more thoroughly. There are two waste tanks, one a wrap-around type, the other a custom HMWPE tank made by Tek-tanks. One of the photos in the latter group shows me shining a torch on the top surface, revealing the contents.
tinny tim
28 Dec 2023
yes i see it now! but i though it was an inlet tank and not a waste due to its location
