tinny tim
Active Member
The add states the following
Warning
The cable entry point must NOT under any circumstances be submerged. The mounting thread and cable entry must be above the highest level of the liquid.I just dont understand what it means! are they saying you can unscrew the mounting thread and draw in some of the cable?
https://za.rs-online.com/web/p/float-switches/7621036
But that one states the followingThe depth of the switch can be changed with an extension tube fitted to the screw
SSF67B25B75 | Sensata / Cynergy3 SSF67 Series Vertical Stainless Steel Float Switch, Float, 1m Cable, NO/NC, 250V ac Max, 120V dc Max | RS
Two Independent Switching Points
Lower Float Make on Fall, and Upper Float Make on Rise
Meaning that the on off position is allready set. Or are you saying the tube extends? as I do see it stated in listing
https://za.rs-online.com/web/p/float-switches/8697615
But dose it telescope?
https://za.rs-online.com/web/p/float-switches/2051304
They dont acrually state that they are for wast tank usage. As our friend above stated that a lot of float switches are not suibable for waste
https://uk.rs-online.com/web/c/auto...float-switches/?applied-dimensions=4294688602
rs components???
