Pye_End
Not convinced that a hose left in a locker and used every few months will be better in terms of algae/bacteria/pcb's than the one on the pontoon, which at least is flushed through regularly.
I drain my hose fully after every use, and run bleach through it now and then.Not convinced that a hose left in a locker and used every few months will be better in terms of algae/bacteria/pcb's than the one on the pontoon, which at least is flushed through regularly.
I haven't used a marina hose ever since I saw a large dog piddling all over one in Haslar Marina.
I only have space for a 'flat' cassette hose, and can't see any way to dry this after use. Drying a normal one must be fairly hard as well I would have thought. Perhaps a hair dryer attached to one end?
Their biggest fear is pollution getting back into the main supply, primarily driven by the incident in Camelford some years ago when 100000 homes ended up with a problem.
What they don't tell you is that the force to expand the X-Hose has to come from somewhere, the water pressure.Anyone tried this?
Anyone tried this? http://www.robertdyas.co.uk/P~163449~X-Hose-25ft-Garden-Hose
That incident was caused when a water board employee dumped 20 tons of aluminium sulphate into the wrong tank at the treatment works, scarcely an apposite comparison.
No, but I did notice someone using one halfway down our home pontoon. Didn't stop to ask him about it as I'm reasonably happy with my roll-up flat one.
we liberated ours from the marina when they took them away & left them in a trolley over the w/eThere was a chap at SIBS flogging them. The demo he gave was very persuasive..... so much so that I bought one.
Haven't tried it yet.
Seems like a good reason (one of many) for banning dogs instead of hosepipes.
It is not anything to do with the HSE, its the water regsThis is an EXCUSE.
All they have to do is put up a sign saying water non-potable and they have no liability.
The only reason they are removing their hoses is because they know they will give away less water and water costs are significant. However what ever it costs, it is certainly covered by mooring fees. Get together and complain, there is no reason for this and if necessary contact the HSE directly, I am sure that they would confirm that signage would be acceptable to them.
I wonder, do they have water regs on the islandIt is nothing to do with either (at least, not in the case of the OP) since this is Guernsey.
