marcon tomahawk
Slinky Spring
20 Jun 2003
merseyside
I have seen various Tomahawks for sale across the net. The price and descriptions appear to fit what I am looking for. I am interested in your opinions about them, any faults to look for and any other suggestions for similar sized boats that I should consider.
Ian Reid
paulrossall
22 Oct 2001
I did look at one a few years back and was told they are well designed/built. There was a review in PBO Dec 1999 page 52 according to my search on the PBO site. Paul
<hr width=100% size=1>" there is nothing-absolutely nothing-half so much worth doing as simply messing about in boats".
Robin
30 May 2001
high and dry on north island
Very nice boats though not huge for their size especially by modern standards. Marcon were the builders and in their day were of a comparable size to Westerly or Macwester. Many if not most would have been home completed from kits of pre-fabricated internal woodwork etc. so quality of finish may vary considerably, both fin keel and twin keels were available. From the same stable as the Trident 24 and the Sabre 27.
johna
12 Aug 2001
Poole
Ian
Have a good look at the Sabre 27 it has very good accommodation and is a good sea boat. Also there is a very active owners association. I owned a sabre for six years prior to having my present boat. Look at the web site <A target="_blank" HREF=http://www.sabre27.org.uk>http://www.sabre27.org.uk</A> I declare an interest as I am still web master.
mcgarry1
N/A
25 Nov 2003
plymouth
my friend has had one for only a year now and he swears by it's quality. i have sailed it an find it a good boat, easy to manouver and very stable, his has a bukh 10hp diesel and he has commented on it's reliabilty and easy of control under motor, his is the fin keel version.
pete
Here
Good boats tough and quite quick, weak point can be the rudder tangs as they can rust loose from the stock, many boats have had there rudders checked usually indicated by a large patch on the rudders side where a piece of glass has been removed for internal inspection and then reglassed same applies to Sabre 27 (as well as many other boats)but if a problem is found it is not two much of a job to correct and should not put you off.
