D
Deleted member 36384
Guest
Context: Older person, UK cold waters, only the wife on board, assume she is not strong or the best sailor but does have a clue.
To haul yourself into the dinghy is going to be very hard and you will exhaust yourself in seconds unless its set up for hauling yourself in. The analogy is that it takes 25% more energy to swing a punch and miss, than swing a punch and strike the blow - fact. Entry from the rear if you have sponsons could be better as weight on the side is likely to tip it over your head. As kids we did this a lot playing about in boats and I was a lightweight. If you are fit enough to haul yourself into a dinghy, then climb up the ladder on the stern if it lowers below the water line. Getting into a dinghy is much easier with flippers (dont divers just hate that word) and additional suit buoyancy.
Getting into a liferaft by yourself is hard when young and fit. I have done this many times in environmental pools for offshore platform training and I needed help the last time I did this. The type with the ramp that allows you to slide up and over the top tube is good. If you have to put your feet into a stirrup and pull up with legs and hands, forget it if you have no fitness. The lifejacket does not help in getting you into the right position either. More energy is expended trying to compensate for the lifejacket when hauling the body up.
Launching the liferaft would be a good idea in a short handed MOB but I reckon you have to try this after swimming a length, fully dressed, in a cold pool, wearing a lifejacket on one of the Sea Survival Courses just to see how practical it is for your age and level for fitness.
Now my point. It is possible with one of these carabiner boat hook devices to attach a rope to a helpless victim and it is possible on a yacht with larger sheet winches (or an anchor windlass) or a tackle system for the wife to haul in her soaking, helpless husband by the lifejacket D ring or harness straps. There a comments in this post about rigging up devices as being too complicated, in dismay, makes you feel good, b o l l o c k s. It's not by far and AliMs post sums it all up.
Instead of detailed solutions lets see how many ways we can pull someone out the water: -
1. Halyard
2. Mainsheet tackle
3. rope and sheet winch
4. rope and anchor winch
5. tackle tied up to shrouds with a rolling hitch
6. tackle tied to the back stay
7. Topping lift
8. tackle from the boom
9. spinnaker pole and pole lift
10. Kicking strap
11. Assisted ladder climbing
None of the above is hard for your average yachtsman to work out how to make it effective, as are the means to make it effective available in any chandlers.
Stopping the boat under sail, switching on the engine and coming back under power, is harder but not impossible, because we do it every time we go sailing.
My own method tried against the pontoon does work and provides quite a powerful lifting device but this thread has introduced many more options which could be a lot simpler.
I prefer SWMBO to put something on that works, than take something off that wont! I will take AliMs advice and experiment with some of the ideas here because I am worth it.
Goodluck and fairwinds this season.
1. Halyard
2. Mainsheet tackle
7. Topping lift
10. Kicking strap
