scruff
I was in the Azores last month (Via 747, not yacht sadly). One of the cruising boats in Horta had a 6:1 tackle permanently rigged to a halyard which I have since copied.
In lieu of a photo, I'll try to describe - A purchase set up, on the lower block I have a webbing strop, long enough to go around ones chest. One end of said strop is affixed to the lower block. On the other end of the webbing strop is a climbing carabeener. As such if you are wearing a life jacket, the carabeener can affix directly to the harness point, if you are not wearing one then the strop can go around your chest.
The upper block of the tackle is hoisted far enough up the mast that the casualty can get over the stanchions on either a long tether (carabeener direct to life jacket) or short tether (around chest). This is permanently hoisted in front of the mast on a spare halyard. The extra rope needed to drop the strop into the water is kept flaked into a netting bag so should not tangle when deployed.
Hopefully i will never need to use it in anger.
