kingsebi
Thank you for explaining.How big was the boat?
Up to about low-30s, not technically needed.
My Stiletto 27 did not have any winches and I never wanted them. My F-24 has 4 winches, and I use them all. My PDQ 34 had 6 winches, but I only really needed the primaries, because the jib was a big lapper. It depends on how the boat is set up.
- Sails can be hoisted at the mast hand over hand. Tension with a strong Cunninham, no problem. You can also use a 2:1 halyard (I did on my F-27, but only because the sail hoisted with the luff tape in the groove, not sliders).
- Jib somewhat smaller and 2:1 sheet. head u p a little when you need to trim in.
- Tackle on mainsheet.
What, no padlock on the chain? I figured you had a coffee-stealer in the crew that would not brew their own share.
Moitessier‘s boat: Joshua (ketch) — Wikipédia
Fortunately my crew doesn’t like coffee. Apart from that nothing is safe.
