Wansworth
Possible new boat does not have a sprayhood are there any published plans for making one?
Yes I made the salesman sew at least four thicknesses of canvas,bit od for curtains and pillow slips but I was thinking of possible cuter uses?Do you have a sewing machine man enough for the job?
Thanks,what about the pipeworkHave a look at the Sailrite web site, I made mine following their 4 hour plus video and am very happy. A lot, lot of work, I made my bimini as well and I reckon the sprayhood takes 2-3x, not far from 40 hours.
Quite some vidnodoubt I can get the metal work here in VigoThanks,what about the pipework
I used the old piping (for the bimini I had it made locally, I was in Spain then Cadiz area and they asked 500euro, 40ish boat); my previous sprayhood had a shape I did not like, so I slightly modified the position of the existing tubing, fixed everything in place with tape and then followed the video for patterning, marks, etc.Thanks,what about the pipework
Yes Vigo isa major ship building port and one of the best yacht builders ,Lagos in bouzasI used the old piping (for the bimini I had it made locally, I was in Spain then Cadiz area and they asked 500euro, 40ish boat); my previous sprayhood had a shape I did not like, so I slightly modified the position of the existing tubing, fixed everything in place with tape and then followed the video for patterning, marks, etc.
ps a friend overwintered in Vigo area and in his words : "you can have a new boat built and equipped here", myself simply passed by in the area so I really do not know.
As with anything where there is a high labour content but freely available materials there is a potential saving DIY, but a lot of skill and time involved to get a good end result.
A bit of a sideways drift, I suppose, but seems a good time to ask this, as it relates to skills and materials required for this sort of job.
My winter cockpit cover has seen its best. The zips are breaking down with teeth missing and the stitching failing.
What Id like to do is replace all the zips with some that are meaty and more robust. Where can I buy lengths of zip strip along with suitable thread. I assume I could use the existing needle work tracks/holes in the canvas edges to sew in the new zips, so they should match accordingly. Maybe I’m overly hopeful that I could do this. Certainly save me a lot of cash, which I don’t have.
Open Ended Chain Zips > 2 metres - MarineA bit of a sideways drift, I suppose, but seems a good time to ask this, as it relates to skills and materials required for this sort of job.
Any good sailmaker will make up a sprayhood.Possible new boat does not have a sprayhood are there any published plans for making one?
Zips, after having tried a few I now only use YKK, 10mm. You can use V69 thread, which normal machines should be able to handle. A lot of difference in UV resistance can be obtained by sewing sleeves over the zip from both sides, as to keep it all covered from sunlight.What Id like to do is replace all the zips with some that are meaty and more robust. Where can I buy lengths of zip strip along with suitable thread. I assume I could use the existing needle work tracks/holes in the canvas edges to sew in the new zips, so they should match accordingly.
We made a replacement last year, paramount is making the patterns using dedicated pattern material from Kayo Spruce. The Sailright videos are good. We used a Singer 201k, more than adequate. Check and check again before cutting, think carefully as others have said about the sequence so that big bundles dont have to go through the harp. Also make sure zips are covered by material. They will rot otherwise, We used the thicker V 92 threadPossible new boat does not have a sprayhood are there any published plans for making one?
The "harp". Never knew it was called that. Lovely description.We made a replacement last year, paramount is making the patterns using dedicated pattern material from Kayo Spruce. The Sailright videos are good. We used a Singer 201k, more than adequate. Check and check again before cutting, think carefully as others have said about the sequence so that big bundles dont have to go through the harp. Also make sure zips are covered by material. They will rot otherwise, We used the thicker V 92 thread
Cant remember, I know we had a few issues with the thread galling but tried needles till it worked. Cranked the shuttle tension up really tight. The thread V92 from Kayospruce was v shiny. Once we got it going though it was easy peasy. I was the "Holder of the Material" as the Boss did the important stuff.The "harp". Never knew it was called that. Lovely description.
What needles did you use with the V92 thread?
