dunedin
Rope lashings often give a smoother and finer alignment - particularly as this one will vary as the boom swingsAn extra shackle is all that is needed to lift the block from catching on the deck
He is right. It is well known and accepted in engineering circles. Ball bearings are fine for continuously rotating loads but they are a disaster for shock loads. The shock caused the balls to impact the races. Roller bearings are not quite so bad.So some of the most respected names in sailing hardware are just prostituting themselves by selling inferior products? Are you really saying that?
I'm definitely swopping to dyneema, anything for a friction free life!![]()
I would assume that all depends on the loads involved.So some of the most respected names in sailing hardware are just prostituting themselves by selling inferior products? Are you really saying that?
A 40' boat would likely have a 400 sqft main. Rigs are generally designed to a loading of 1 lbs/ sqft = 400lbs load on the main sail. I triple block = 1/3rd load per bearing = 133 lbs, which is peanuts by the way, and as far as I am concerned there is not really anything static on a sailing vessel; there is always some movement in a sheet. Consequently, there is no one locked pressure point on a sheave bearing.
BTW, I think ball bearing blocks are a fine thing.
I’m afraid you’re wrong. A Rockwell “C” hardness tester uses an inverted pyramid shaped indenter. The size of the indent is measured as the average across the diagonals and calculated from a chart.I would have called that a Rockwell hardness test & the technology came out of the ark so nothing rocket science being quoted there & proves SFA really.
What does prove things, is the practicality of actual use & most experienced sailors (whether part time prostitutes or not) know that decent quality high load bearing blocks, properly rigged & set up, are far nicer to use than cheapo plain bearing. You can argue all you like but that is fact.
Where is Brent Swain when we need him?![]()
The first time I used ball bearing blocks I was blown away by the ease with which one could adjust the sheets. I doubt they wear out all that often and if they did they tend to be in places that are easily accessible.
You would not use a Brinnel test on ball bearings , roller cages & the like because it is for soft material. that is why I assumed Rockwell.I’m afraid you’re wrong. A Rockwell “C” hardness tester uses an inverted pyramid shaped indenter. The size of the indent is measured as the average across the diagonals and calculated from a chart.
Mike
The forward double block is probably the the one causing the most trouble, because if the twist induced by the line going forward.
A better set up would be with triple block at the aft point on the boom and a single block forward.
You would Al's do better with the aft boom block directly over the one on the track.
