CaptainBob
I found a used Magma Barbeque in a chandlers for £85 a few months ago and it's been absolutely flippin fantastic! While aboard, I've literally used it every other day.
Only problem is I'm really seriously getting through the little propane/butane cylinders it takes.
I've seen that for £50 I can get a controller for it which means I can plumb it into our boat's gas system. But I'm willing to put in a lot of effort to avoid spending £50 on something I don't really need!
So I worked out a way to connect the boat's gas system directly in to where the small cylinders plug in to their controller, and fired it up.
It works - but the flame is so low, even on max, that it blows out all the time and isn't really enough for cooking on. Presume this is because the little cylinders are higher pressure? Or because they're butane/propane mix and the boat is pure one or the other (I forget which and am not aboard at the moment).
Am I going to need to bight the bullet and get the £50 controller?
TY!
TY!
