scr0che
I've got a Madrid 35F fridge bought from Penguin couple of years ago that's stopped working, struggling to identify the fault.
I've been going through the troubleshooting in the manual and this is what I've found:
The compressor is not starting.
Noticed this on passage, it was intermittent initially, but not starting at all now.
On passage noticed a metallic tapping coming from the unit, had a good look at the time and couldn't see any moving parts, tapped even when compressor off, like something came loose inside?
Control panel voltage 12.62, fused rocker switch, when on 12.62, off 0.0, swapped switch out and same values, switch working OK.
Voltage on fridge end of wires (coming from switch when on) is 12.62, which is ok, its worked fine fine for 2 years, connections clean, wires ok and appropriate size
However, when I connect the wires back on to the control unit and test while connected, voltage is 5.8?
I bridged C and T to eliminate thermostat, with it bridged or disconnected completely, or thermostat connected, same voltage 5.8 when tested with wires connected from switch.
So voltage is good on wires at fridge, but when conneced to controller drops to 5.8, ive no idea why. Can anyone suggest what to test next?
Will get an led tomorrow to try and get an error code from the blinking.
