vic008
Work with machinists, was wondering would it be possible to make your own cones for the older Norseman terminals, that are not available now.(All on holiday now of course)
Replace with a non norseman type?
And that just proves you know SFA about machine work. The original sequence is how they would have been made originally. Drilling the hole last would lead to excessive drill breakages.I'd do everything before drilling the hole![]()
I am not sure that the original sequence is how it would be done commercially. I think the external diameters and tapers would be cut on a bar fed capstan lathe, quite possibly CNC automated. It is possible that the sequence would be to drill the hole first from a tailstock capstan, then the drill would withdraw to be replaced by a polished and lubricated rod that would act as a steady (or by a rotating steady). The long taper would be turned on the outer end of the bar from the lathe bed capstan, followed by the short taper being cut by plunge cutting with a form tool that would also part off the piece. After that the slitting operation would be performed with the part held in a purpose made fixture on a horizontal milling machine. I very much doubt that a commercial producer would go to the trouble of putting the part onto a mandrel with Loctite, then heating it to get it off again.
