Porthandbuoy
nonsense.
Exactly. The gas between the bottle and cooker is pressurised, and stays pressurised for days and weeks after the both are isolated. So that brief hiss of gas is a good indication my system is leak tight.
nonsense.
When boating on inland waterways as in CRT waters bubble testers are part of the BSS, so cant be bad thing, they are for safety or they would not be part of the BSS.
Easy enough to fit if you have a big enough lpg locker, so its a choice of the boat owner, no big deal.
Proves my point, another boat owner who's irrationally frightened of LPG. If it's that dangerous, why do you only check it once a month? Why not weekly? Or daily? Or every 5 minutes just in case a leak has suddenly appeared in solid copper pipework?
I just love experts!
While bubble testers are in the spotlight is perhaps a good time to remind users that the function of the bubble tester itself should be tested from time to time. They can become blocked and fail to indicate a leak . Details of the function test are in the instructions
Indeed, I started a thread last March about bubble testers, http://www.ybw.com/forums/showthread.php?475617-Gas-leak-detector
Test it yourself every so often, easy enough to do. If it is not functioning properly it is a liability.
The regulator with built-in pressure gauge sounds good. Not come across them before as it's over 30 years since I did my last LPG installation. Who sells them please?
They're sold by a company called 'Gaslow'. Mine's on camping gaz but i'm sure they do others. Unfortunately they're not really marine grade, but I use them because it's very difficult to achieve a sealed gas locker on my little boat and so I need to be able to check the entire system from bottle to cooker.
The idea is to turn the system off at the bottle and check the gauge is showing that pressure is remaining in all of the system.
They're available in most caravan shops and online, and I replace them every few years.
i've lost the instructions for the bubble tester - so how do i test it? i do remember reading never to try it whilst the cooker has a burner lit. thanks
Surely if everything is turned off and the bubble tester is bubbling that would indicate a leak.
