3663Ian
Active Member
Has anyone come across a problem like this.....
When powered on from the main distribution panel switch, the unit starts on its own and then goes into a constant cycle of bleeping and backlight on off. The chart is being displayed overlaid by the usual "not to be used for navigation" message. Pressing the power button stops it bleeping for a few seconds while it restarts then the cycling starts again. In this state the unit cannot be turned off as it will always restart on its own when the main power is on.
I have disconnected the antenna and the behaviour is unchanged other than the additional lost signal message which appears on the display.
I am certain that the power connections are OK. I have done both hard and soft resets.
This problem has occurred previously and I resolved it by wiping to contacts on the map SD card and reseating the card. ( of course it is possible that this was just coincidental). I have now tried my old chart card and this behaves the same.
The problem appears all the time at the moment.
As the problem has been intermittent I suppose that it is not something completely terminal so any advise or experience with fixing these units would be much appreciated.
Ian
Ian
