Low Voltage to EVC
Monterey400
28 May 2024
I have Twin VP IPS 500 370 hp engines. I am getting a low-voltage to the EVC alarm, and the Joystick cuts out. I have replaced the batteries with AGM as a precaution because they were not charging correctly. I have also gotten Total Steering and Throttle Failure once. Codes pulled while in OEM Mode are 164 PSID 99 FMI 12. I think that it may be an alternator issue. Does anyone have any ideas, or at least does anyone know what these codes mean?
Andyroonot
28 Nov 2009
The code explanation is not really very easy to advise on via a message here, and certainly doesn’t relate to battery voltage, Joystick or steering issues
Do you have any other codes?
Have you had anyone check for (and apply) any software updates?
Does this happen all of the time or just randomly?
Monterey400
28 May 2024
I keep getting a low battery to EVC alarm on the port engine. I did get a low voltage to SUS alarm once also. Thinking it may be the alternator.
