Lost prop
SimonD
27 Nov 2001
Dorset
My Bruntons three blade varifold prop has fallen off and I'm looking for bright ideas on how to get it back.
It's in Port Solent Marina in about 2.5m of water. I've got a pretty good idea where it came off and I'm told the bottom is chalk with a layer of silt over it.
I'm hoping to be able to find it by dragging some sort rake over the bottom (unless anyone's got better ideas). Then, I thought of two ways to get it up: some sort of scoop on a pole, or a rope with weights and hooks on it to try to tangle round the thing. (BTW, I'm assuming diving into the water to drop a loop of rope round it would make me very unpopular with the management.)
Any other bright ideas? At £800 a pop, I'm quite keen to get it back!
Simon
PS I can't rate the staff at Port Solent too highly - they really could not have been more helpful in getting me back home sans prop. Brilliant customer service.
Genie
10 Dec 2006
400m West of L\'Omptolle
Sorry to hear of your mishap.
At £800 a pop I would don mask, snorkel and dive down with rope to pull it up!
I'd rather be £800 better off and suffer someones indignation than lose it.
Surely they would understand that sometimes the ends justifies the means?
However, if by 'management' you mean your other good half, then methinks involve her in the 'rescue' by getting her to help out - 2 heads are better then one!
Good luck with the 'rescue'!
Jonny_H
15 Aug 2006
Liveaboard - following the sun!
www.freewebs.com
Have used this method to remove a rope from around a prop in a marina (one person holding drain pipe - other person with a broom handle and hacksaw blade taped to it) - so can confirm it does work! Although at 2.5 metres perhaps you might want to tape a torch to the end of the tube to help light the way!
SimonD
27 Nov 2001
Dorset
You'd think so wouldn't you. But apparently because it's in a marina there has to be two divers, lots of insurance etc. Costs around £400 for half and hour with no guarantees.
savageseadog
19 Jun 2005
I tried to find a prop in a canal once when I was a diver. It was an impossible job. If its anything like most harbours there isn't exactly a bottom, it just gets thicker, you can't see a thing and there will be all kinds of debris everywhere. Unless you know where it is to less than a 3m radius it's not findable. The problem with trying to scoop it up it that it's likely to be down into the mud, anything in the way of a scoop will skate over the top of the mud above the propeller.
Having said all that if the bottom is at all firm you might stand a chance and I would give anything a go anyway.
SimonD
27 Nov 2001
Dorset
I like this idea. Better still, my wife fell off the pontoon and I jumped in after her! I think if the water is clear and I can see it on the bottom, the marina staff would have to have a heart of stone to stop me going in after it.
A
Anonymous
Some metal detectors work underwater; try www.joanallen.co.uk who are one of the best specialist retailers. Once you know where it is, it is easy peasy /forums/images/graemlins/wink.gif
l'escargot
Isle of Wight / Jersey
Sounds extortionate and a con. Only one other option - wait for a low tide at about 3 am and sneak in and open both lock gates.
Kawasaki
21 Jun 2004
Anglesey Wales
The Magnet thingie You have is Great.
Tiss however useless at picking up or attaching to any Non Ferrous stuff.
IE. it will only stick to bits with iron or steel in them.
Don,t like copper or brass or aluminium and such like.
sarabande
6 May 2005
Don't worry, the English Speaking Union has just banned the the use of the word "gullible" from the next edition of the Oxford Dictionary.
If the prop has got any ferrous bits in it (sleeve, bolts, etc) the Sea Magnet will pick up the prop easily. It will also pick up old tin cans, spanners, shackle pins, anchors....
The key function will be to locate the prop. Even a White XL metal detector with a waterproof head (or an ordinary loop one in a proper plastic bag) will be hard put to find one on 7ft of water. Calibrating it would be a problem for the ground balancing function. The local dive club might have some ideas or detector kit, though.
webcraft
8 Jul 2001
Cyberspace
www.bluemoment.com
Sounds ridiculous that you cannot just go in and get it.
Wetsuit, snorkel, mask and slide in quietly.
No-one will notice if you slip in subtly without making a fuss.
If they do pretend ignorance.
- W
