bikedaft
The Loss of Solution on Return Delivery - Newport Bermuda Race
a sobering read. could happen to any of us.
It still surprises me that the USCG winching method involves the casualties jumping into the sea.
They have solved the winching a different way. They use swimmers and baskets rather than a winch person and a strop.It still surprises me that the USCG winching method involves the casualties jumping into the sea.
We have a sounder on our main bilge pump. It runs every time the pump runs. We only get concerned if it doesn't turn off! Every part of the boat drains to this main bilge pump, located in a sump over the keel between the two inbuilt tanks (diesel and water).I have sailed mostly on wooden boats and had the seams open up in rough seas on a few occasions. It sounds like this boat was well looked after and they did what they could given the circumstances. I had water above the floorboards in the middle of the night under sail to St Kilda as she loomed out of the darkness. Small electric bilge pumps did less than the manual job! The only thing was to turn around and put her on the other tack so that the seam that was being opened was now in compression rather than tension of the rig. That did enough. When back at home port some sawdust under the hull filled the seam and stemmed the leak.
We were at sea for 32 hours with myself and father for crew. Our engine had also given up due to sloshing when a bit low on fuel but I was able to restart it after filling the tanks from Jerry cans although the deck became treacherous with the spillages that occur when in breaking seas. A Racor fuel filter and a bulb I had installed made things a lot easier. It was an old wooden boat so to be honest I was not overly surprised and we just got on with it, these things happen. If 200 miles from land things may have been different.
My take home was that you need a very good engine system with double Racor filters. Most importantly you need a way of detecting a leak early so that you can identify where is stems from and take action.
Fair play to the skipper here who did what he could but didn’t get precious when it came time to make the decision of risk to crew or boat.
I've been on a few jobs with RAF (and now Bristows) helicopters where they've had to winch from an awkward location, and we used a hi-line as opposed to winching from directly overhead.They have solved the winching a different way. They use swimmers and baskets rather than a winch person and a strop.
the newer helo's have greater downdraft, e.g. S92, - hence they do prefer a hi line.I've been on a few jobs with RAF (and now Bristows) helicopters where they've had to winch from an awkward location, and we used a hi-line as opposed to winching from directly overhead.
It worked every time with no problems. The only potential issue is that you need someone on the vessel to manage the hi-line.
My bilge pumps have always been monitored but on a boat of our type it was not unusual for the pump to cycle off and on in any case. The boat was always a bit leaky from above and below and routinely we would count the strokes of the manual pump (which went deeper than the automatic) when we arrived at a destination. This would let us know if there was any significant change in the natural flow of things. We now, also have a plastic boat with a dry bilge. I would want to know immediately if there was water and where it came from. I intend to fit sensors in each compartment of the bilge to achieve this. A small amount of arduino (or other uC) fiddling should be able to give an indication of which compartment any inundation came from and hence which through-hull or area we should look to first. In a flooding the key is rapid identification of where the water is coming from and stemming it. No pump will save you from even a modest leak as pumps have remarkably low volume output in comparison to a broken through-hull etc and all pumps fail eventually. We have had many an occasion when our pumps failed in routine operation either because of a bit of dirt or just their rather hostile environment. I consider the pulps to be a way of tidying up after the event rather than a way of saving us from the event. Find it, fix it, tidy up.We have a sounder on our main bilge pump. It runs every time the pump runs. We only get concerned if it doesn't turn off! Every part of the boat drains to this main bilge pump, located in a sump over the keel between the two inbuilt tanks (diesel and water).
There are 3 additional electric pumps including one emergency pump. All on float switches.
The fuel system has 1/4 turn fuel filters. Both easily accessible. You can swap them in 30 seconds. Self bleeding fuel system with electric pump. In addition, we vacuum the bottom of the fuel tank every 6 months to remove any crud.
I never see the point of a high level bilge alarm. Your bilge pump is the alarm. Just fit a sounder to it that can be heard in the cockpit. Being a 24v boat, I fitted a lorry reversing sounder. It's loud
it's not that difficult to manage if you have not done it before - just don't tie it to anything(!) - it mostly is to stop the winchman from spinning.
My four pumps are sized to cope with the loss of a skin fitting. That is the reason why I have four pumps. The pump in the deep sump functions as the alarm. The bow area is behind a crash bulkhead. The bulkhead is fitted with a 3/4" through hull to a pipe that runs all the way to the main sump. Same in the rear bulkhead where the rudder shaft is. By lifting the floor panel by the main sump, you can see if the front or rear pipes are flowing or if the water is entering the bilge from the port or starboard side. This is enough to narrow down the location of a leak.My bilge pumps have always been monitored but on a boat of our type it was not unusual for the pump to cycle off and on in any case. The boat was always a bit leaky from above and below and routinely we would count the strokes of the manual pump (which went deeper than the automatic) when we arrived at a destination. This would let us know if there was any significant change in the natural flow of things. We now, also have a plastic boat with a dry bilge. I would want to know immediately if there was water and where it came from. I intend to fit sensors in each compartment of the bilge to achieve this. A small amount of arduino (or other uC) fiddling should be able to give an indication of which compartment any inundation came from and hence which through-hull or area we should look to first. In a flooding the key is rapid identification of where the water is coming from and stemming it. No pump will save you from even a modest leak as pumps have remarkably low volume output in comparison to a broken through-hull etc and all pumps fail eventually. We have had many an occasion when our pumps failed in routine operation either because of a bit of dirt or just their rather hostile environment. I consider the pulps to be a way of tidying up after the event rather than a way of saving us from the event. Find it, fix it, tidy up.
The pumps are rated for smooth bore pipe lifting a certain head at a certain voltage. All of this is great data and you can calculate the actual lift these pumps will do. I did the calculations and sized the pumping capacity based on the data, allowing for the pipe loses and the vertical lift. It helps that as a young engineer, I used to do these calculations by hand, before computers.I use Rule pumps also. They seem reasonable but no pump puts out its rated capacity in the real world so worth testing. On a deep dive into this subject I concluded that only an engine driven high capacity pump was likely to keep up with any serious leak. Engines and batteries fail and often at the wrong time such as when they are being sloshed about with sea water. Old wet wooden boats and dry plastic boats with watertight bulkheads are different things. I don’t rely on pumps to get me out of trouble but certainly better having them than not. The Lidl electric trash pumps have come in handy in the past and they do move a lot of water. Used at the dock to keep afloat!
But not much use in a crisis when the one man is the total crew. He is best employed finding the leak and dealing with whilst the pumps do their best to remove as much water as possible. A totally different issue on a boat with plentry of crew. With 2" hole in the bottom you can see up to 20,000 litres of inflow per hour. That bucket won't do much"Nothing moves water like an anxious man with a bucket !"
Maybe, but many (most?) here aren't in their first flush of youth, so for how long?"Nothing moves water like an anxious man with a bucket !"
