Clyde_Wanderer
Hi all, Lifted my boat onto its cradle yesterday, discovered the keel is a little loose, slight sideways movement, but she never took in any water around the keel nuts in the bilge while in in the water, infact she hasent taken in any water at all while on the mooring.
The keel is aprox 4"thick at the joint, 6ft long and about 3ft 6" high, and I would estimate somewhere from 750 to 1000 kg, I was told that the studs would be stainless steel, but I very much doubt that s/s would be used in a cast iron keel, can any of you good forumites cast a view on this and suggest the least costly and most secure remedy for me to carry out myself.
Would I be best to drop the keel down a few inches to inspect the condition of the studs, and reseal it? or just try tightening the nuts inside the hull and hope for the best?.
Thanks for any advice, Eamonn.
