scozzy
Hi all, quite possibly a stupid question so looking to confirm what I think...is the answer ...
Trying to get yanmar 1gm10 started with no joy with usual remedies (bleed,easy start hot air in intake etc)
So decide on compression test and go to take out injector....
2 things...came out v easy and clamp itself was in fact loose on applying wrench
So...thinking loose clamp will cause leak and therefore rubbish compression? Yes?
Second it seems that the injector should be quite hard to remove and it definitely wasn't...am guessing cranking over " popped" injector and made easy to remove whilst unaware it was in fact loose!?
Long story short will check spray pattern etc while it's out but could..After all my faff..a loose clamp on injector be the initial problem with starting?
