Denngeor
New Member
Any opinions on outboards in the 2.3 to 3.5 hp range?
Shame about the oil they leave behind. They’re better in every way apart from that. I’d use one if I berthed in Portsmouth, or somewhere like that. My feathered friends near my home berth wouldn’t like it.Many of us prefer the old Mariner//Mercury 2 stroke second hand, as light weight and simple.
No late night shopping here, mate. The sun hasn’t even set here in Tasmania. What happened to the first Suzuki? Helpful reply. CheersLate night outboard shopping Denngeor?!
I've had Honda, Yamaha and 2 x Suzukis. There's no best one in my opinion, although some YBW members are evangelical about their choices of marine equipment.
Honda, air cooled so doesn't need flushing but too noisy for my taste. Don't like the lack of gear selection, start it with a bit of throttle and you're moving.
Yamaha, better quality but heaviest, water cooled and has gear selector for forwards. Ironically i had this serviced at a dealer to maintain the warranty but they overfilled it with oil so much i thought it was going to catch fire in the middle of the river.
Suzuki, lightest, water cooled, gear selector for forwards, lightness is reflected in quality.
The first one went pop under warranty, dealer Gillingham Marina were awful in regards to honouring warranty. New one bought last year works fine.
Personally I'd only run whatever you buy on lawnmower fuel, the Aspen long life stuff. Pretty much all the aggro outboards give is from stale petrol.
I’m sure I read a post here recently that said they still had an impeller for cooling the gearbox or something.Honda, air cooled so doesn't need flushing
I wouldn’t use our two stroke on an inland lake - but never noticed any noticeable trace of oil in general use. Very minorShame about the oil they leave behind. They’re better in every way apart from that. I’d use one if I berthed in Portsmouth, or somewhere like that. My feathered friends near my home berth wouldn’t like it.
Did it drop a valve or just a pushrod? I have one that I ran on avgas for a bit (don't ask) and next time it had no compression, exhaust valve had stuck open and pushrod dropped into sump when the cam lobe moved an easy fix with a magnetic probe to fish out pushrod but head needed off to clean deposits off valve stem.Sorry hadn’t noticed that!
First Suzuki dropped a valve, dealer wanted £250 to fix it even though it allegedly had a 7 year warranty. At the time they were about £500 new.
Thanks for the suggestion but electric won’t work for me for several reasons.Depending on your requirements could an electric work? I’ve had the Tohatsu 3.5 2 stroke and the 2.3 air cooled Honda mentioned above. Hated them both as if only used occasionally you need to run them dry or they won’t start next time due to the fuel residue gumming up the carb. A couple of seasons ago we got an ePropulsion eLite instead. It always works, is quiet and my partner and the kids find it far more user friendly. Range is not great but we only use it to get in and out when anchored.
Gillingham Marina Chandlers said it had dropped a valve and claimed it wasn’t covered under warranty as apparently caused by ‘dirty fuel’.
I’m no engineer but that sounded like a load of BS to me.
Baby Honda.
Noisy but..........
4 stroke. No 2 stroke oil to buy ,locate where you stored it and fill.
No impellor.
Neat little expection window to check oil level and conditon.
No internal water cooling passages to corrode or fill up with salt.
No working out exactly when to turn of fuel to empty carb when approaching the shore.
Just ensure you lay it the right side up and no car boot reeking of petrol/two stroke mix.
Forget the Chinese junk as well , sometimes the paint stays on for whole weeks after purchase before flaking off.
