SimonX
Hello all,
Thanks for adding me to the forum.
I’m a semi-retired owner of a small logistics company and have owned a 1999 Bayliner 3055 for just over 6 years, using it mostly at weekends around the Solent area coast with occasional longer trips to Dorset and Kent.
This summer, having passed the day to day running of the business to my assistant, now general manager, we had our first bigger trip, over to the Channel Islands and St Malo and this has wetted our appetite to do some more. Probably to the same area and further in Brittany but the good lady (who had Belgian and Dutch parents) also keen to go up to the Netherlands and onto canals there and in France.
Unfortunately it also highlighted that the Bayliner isn’t great for these longer trips. The main issue is fuel cost and consumption. Running two 220hp Mercruiser petrol engines is pretty expensive. We also had some reliability issues with them (water pump failure, cracked manifold, the usual shift cable problems).
Despite being beamy it’s also quite cramped when you are living onboard for weeks. With both beds open onto the galley area and only one heads, it’s a bit too tight for guests once you are getting on a bit.
So we are looking at getting something a little bigger and diesel powered.
A couple of people at the marina have recommended Brooms and there seems to be a huge range of them. Price wise a lot depends on how much I can get for the Bayliner (probably £30-40k) but probably around £100-120k spend so a Broom is going to be around the same age or a little older for that price.
Models 35CL, 36, 37, 38 seem to be suitable although all the 35CLs I can see currently listed are single engine 135hp which seems a bit weak for channel crossing and anything but close coastal.
I’ve had a read of some other posts on here and it seems I need to be looking for twin diesels ( best brand?) bow thruster, folding radar arch, generator.
Any other features I should look out for ? Other similar boats?
Thanks in advance.
Thanks in advance.
