snowleopard
The reason that this subject raises so much discussion is that both answers are right according to the speed of rotation of the prop.
When stationary the blades are stalled and have a relatively low drag.
Allowing the blades to rotate causes an initial increase in drag, peaking at 50-70% of the theoretical freewheeling speed. In a low-friction setup or where some power is applied to the shaft, the drag falls and by 90% speed it is lower than the stationary drag, falling to close to zero at 100%.
So if there is very little friction the speed will be higher and drag low but in most typical installations the friction will reduce the speed of rotation nearer to the maximum-drag condition.
A bench test will only give realistic results if the friction is at a realistic level.
