Locking hatches
Howardnp
21 Jul 2004
Worcester
Can anyone tell me where I can get some locking hatches.
I am changing the seat on my RIB and want to use the space under the seat for storage but I want to be able to lock the access.
Need hatches about 380mm square (or thereabouts) with locks.
I know an option is to buy normal no lock hatches and add a form of lock but it would be neater if the lock was combined.
Only place I've found advertising the things has spent nearly two months waiting for a supply, so I've cancelled my order.
Anything at SIBS?
Talbot
23 Aug 2003
Brighton, UK
I would strongly recommend talking to <A target="_blank" HREF=http://www.seateach.com/Hatch/Lewmar.asp>SeaTeach</A> (after the show). They have a larger range than anyone else, and expect that what you are after isa locking version of :
snowleopard
Oxford
can't make out the details in the black - is that a bomar or similar?
i need something of the sort but the plastic ones i have seen so far have a recessed groove which will collect water when used horizontally - does anyone know of something which will keep the contents dry?
Talbot
23 Aug 2003
Brighton, UK
Picture was I think of a bowmar engine hatch. All these hatches have a similar construction to allow flush fitting as a hatch to be walked on, and thus there will be a minor amount of water in the gap between hatch and surrounding flange. This will only enter compartment when hatch is raised!
