dunedin
Bad luck. Best put solar panel and regulator on the jobs list, that’s what has hopefully been keeping our battery bank topped up these past few weeks.
If you don't turn the bottles and the alarm off, like you didn't when the batteries went flat, and there was a leak, the bilges fill up with gas, the alarm runs the batteries flat, you arrive to a bilge full of gas. Oblivious to that, you start the engine to charge the batteries up BOOM
To be fair to the alarm, it bleeps when the battery is low, and seems to be able to maintain that for weeks before dying completely.
I'm expecting to find my battery bank(all two of them) flat and caput after all this time. Having said that they are both at least eight years old and were showing their age so no great loss
Same here. When I eventually get out to Spain and , probably, have to replace all four batteries, I want to set up a small solar charging system to trickle charge them while I'm away. Any recommendations for a system that will keep them topped up safely but not overcharge while I'm not there?
I am assuming (hoping?) that our Victron MPPT solar controller is smart enough to avoid over charging the batteries. It is certainly connected 24x7x365 so I hope so.
There is a prominent notice on my cooker reminding me to turn the gas off at the bottle when leaving the boat. This was installed after I realized I'd forgotten when nearing home after a 400 mile journey! My boat is now kept closer to home.It was that - the knowledge that I am an absent minded and scatterbrained individual - that kept me from wanting to learn to fly and kept me loyal to paraffin cookers on boats for the first half century of my sailing career.
Sadly, I have two penetrations in my gas locker, one for the drain and the second for the bulkhead fitting through which the gas is fed to the galley. The bulkhead fitting is towards the top on a side of the locker, the drain is at the bottom.There should be no other penetrations of the gas locker into the accommodation.
The thing about gas, is that it's a gas, not a liquid.
It won't run out by gravity like water, it will diffuse through holes, even if they are high up.
Gas locker drains quite commonly block.
One boat I had, the outlet at the transom trapped water like the u-bend in a toilet.
I've seen them collect leaves over winter.
My problems started with LPG alarm repeatedly going off. Checked for but could not detect any gas leaks so decided it was a failure of the LPG alarm sensor head. Advised they only last 4-6yrs. Mine was about 8yrs old. Due to age advised the current replacement head will not work on old alarm!
