Littlehamton winter shore storage £22.50 a week - craning in the Centaur - £90 -
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
just in the interst of yachting glasnost
I guess that is fairly standard for the solent area
three boats went in
seven came out
pleased to be afloat
no detectable keel flop as she went up
no leaks
sailing around to Hayling Island on Monday morning
leaving at first light -
then around the Owers and back in towards Chich harbour entrance
the week on the pontoon at Arun Yacht club was £98
across the river with the harbour it would have cost £20 a night
Tuesday I will cycle the bike back to littlehampton to pick up the car
The Pontoon at hayling island will be £50 a week - plus electricity (25p a day for the connection plus usage charge)
D
dylanwinter
28 Mar 2005
Buckingham
Yes . Ive often done the maths.
I keep pretty careful tabs on the costs of KTL
one of the reasons why all those "excellent places to eat" recommendations are a waste of digits for me
I have only eaten out three times over the seven years
two Harvesters and one Indian
as I have yet to sail Harmony the ratio of cost to sailing stack up pretty badly
that will all change this summer and the expense will fade into the distance
D
FWB
N/A
29 Feb 2004
Kernow
Very bad practice to lift a boat like that. The boat could have been crushed, usual way is to spread the load so that the strops hang away from the sides of the boat. Lucky that the Centaur is strong.
JumbleDuck
8 Aug 2013
SW Scotland
The slope in looks like about 1 in 5. If the weight was evenly spread, each end of each sling would have been taking 1000kg or so (assuming a fully equipped Centaur) which is 200kg inwards at each gunwale point.
Seajet
23 Sep 2010
West Sussex / Hants
My club used a crane without spreader bars for decades, boats ranging from 16 - 35' of wood, grp and ferro, no problems.
The secret is having long slings so the pull is vertical, rather than short slings going across the boat pulling the sides together...
Giblets
5 Mar 2006
Surrey
There's definitely something wrong with that engine, Dylan. It doesn't produce clouds of blue smoke when started from cold as all elderly VP 200*s do!!! :D
Blueboatman
10 Jul 2005
Dont forget to add...: That 200kg will be applied to the wooden rubrails. Those strops stretch a tad . Which means there is now a tearing -or shear if you like- force applied to the rubrails' fastenings ( prob alloy rivets glassed over on the inside and as old as the boat).
A vertical lift via spreader bars would allow stretch without friction applied to the wood and fasteners..
Because it is not visible dont mean its not ' there '
Ah well, job done
JumbleDuck
8 Aug 2013
SW Scotland
The rubbing strips on that age of Westerly are 2" x 1" teak, through bolted (1/2" UNF bolts) every 6" or so. A vertical lift would make no difference at all that I can see; the straps would still go round the hull and over the rubbing strips on their way up. The only difference is that the inwards force without spreader bars would help push the rubbing strip more firmly against the hull and resist the shear force better.
