dinwood
We read plenty about Lithium battery technology maturing for use in cars - does anyone know of it being used/available for boats? I know it is expensive now, but how do the economics work out?
.......what can happen is that you end up with a runaway thermal excursion (fire) with jets of flames that can reach temperatures of +700deg C and will burn for a significant period of time!! ........
Rubbish - if its good enough for Scoty aka "she canny take it capin" its good enough for us.
Constitution-class starships continued to use crystallized lithium until the mid 2260s, before switching to dilithium.
It was used in the warp drive systems of many starships. Dilithium regulated the matter/antimatter reaction in a ship's warp core because of its ability to be rendered porous to light-element antimatter when exposed to high temperatures and pressures. It controls the amount of power generated in the reaction chamber, channeling the energy released by mutual annihilation into a stream of electro-plasma.
http://memory-alpha.org/en/wiki/Dilithium
It was only a matter of time until digression was assured
So unless your battery system has some very special packaging to ensure that the cells are not damaged then do not even consider them irrespective of price.
I've been peripherally involved with LiFeP04 cells in electric vehicles recently. They don't suffer from the "thermal runaway" problems that other Li-ion chemistries do. This is from the datasheet:
"Phosphate based technology possesses superior thermal and chemical stability which provides better safety characteristics than those of other Lithium-ion technologies. Lithium phosphate cells are incombustible in the event of mishandling during charge or discharge, they are more stable under overcharge or short circuit conditions and they can withstand high temperatures without decomposing. When abuse does occur, the phosphate-based cathode material will not release oxygen, will not combust and is therefore much less susceptible to thermal runaway. Lithium iron phosphate cells also offer a longer cycle life (1000 - 2500 cycles).
Lithium iron phosphate batteries have lower energy density than cobalt, but they can support higher currents and thus greater power. They are a significant improvement over lithium cobalt oxide cells in terms of the cost, safety and toxicity."
If it weren't for the (eyewatering!) price, I'd not have a problem using them on a boat! They also have the advantage that you don't need different types of battery for cranking and domestic use as they can supply whacking great currents as well as very small currents.
Now there's an idea, using digression as a power-source. A bit like Douglas Adams' improbability drive, I suppose.
