davidmh
A lot of boaty things now have lithium batteries which require charging, I have had lots of conflicting advice on the best way to charge and get a good life out of the batteries. the comments I have had are
Dont let the batterry run out completely, you may find it difficult to recharge.
Dont leave it for long periods with 100% charge, best level is around 60%
Dont just use a liitle bit of battery and then recharge to 100%, or worse still just charge it up a liitle bit.
Batteries like to be used ideal is to use it until it is down in the 10% range then charge it back up to 100% or 90+%.
Dont leave your battery on charge for long periods when it is at 100%
I thought lithium had done away with all the charging problems with Ni-Cad and Ni-MH batteries !!
What is forum views.
uses of battery such as, drills, tablets, dinghy air pimps, elecric outboards, torches, hand held VHF etc
