olam
So why would you use single lip seals when you could fit a double lip of the same width?
What lubricates the outer seal?
What is the application ?So why would you use single lip seals when you could fit a double lip of the same width?
As I understand it, the outer lip of a double lip seal doesn't actually bear on the shaft - the inner diameter of the hole is fractionally larger than the shaft. The outer lip is intended primarily as a protection against ingress of dirt, etc.
+1 and the space between the seal lips should be filled with grease.
For this application that has worked for 20 years I would suggest keeping the arrangement, including seal type, exactly the same.Application is a propshaft oil fed seal.Original seals now 20 years old and not leaking
but i want to replace whist boat is on the hard.
3 X seals,1 x forward keeping the oil in ,1 x aft keeping oil in and second one aft keeping water out.
I have an identical arrangement. Be aware that the existing lip seals may have grooved the propshaft and you may want to replace that as well, if you can't adjust things so the new ones bear on unworn sections.Application is a propshaft oil fed seal.Original seals now 20 years old and not leaking
This is a true double lip seal that seals from both sides and has double springs
